56 buick front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2006, 08:08 PM
Last journal entry: Body removal.....final chapter
56 buick front end
Hi all. I have a 56 Buick Special. I had easy access to a 75 Nova subframe assembly. First measurements show the out to out frame rail dim's on the nova are 37" and my special is about 34.5". Anybody have any experience with adapting something like this. If you're willing to drop some advice I'd love to here it.
Thanks
Dan
Old 10-06-2006, 07:56 PM
jalopy45's Avatar
It can be done but it requires a side step on the frame where the two join, and if it's not exact you will have alignment problems forever.,,You might consider getting a Kanters catalog http://www.kanter.com/ and rebuild the stock suspension and if you want to lower it I think Fatmans Fabrication http://www.fatmanfab.com/ has dropped spindles.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 10-06-2006, 08:49 PM
Thanks for the info. I was thinking there may be a problem once I started measuring. Any idea how different the motor mount setup is from the nailhead compared to a small block chevy? I would like to use something other than the dynaflow trans that's in there right now.
Old 10-07-2006, 09:01 PM
jalopy45's Avatar
Seen a subframe swap in a '57 Buick and they couldn't use the Chev mounts because the radiator support was moved back to fit the Buick body, so they engine mounts will probably have to be fabricated any way you choose to go.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
front end too low mopar 36 Suspension - Brakes - Steering 21 11-19-2008 04:44 AM
front end shake brainsboy Suspension - Brakes - Steering 3 02-14-2005 10:30 AM
'56 fiber glass front end??? 84vettehottie Body - Exterior 0 12-18-2002 06:41 AM
raise the front end of the Chevelle tetzlaff Suspension - Brakes - Steering 3 09-19-2002 10:22 AM
