56 chev. auto trans. shifter - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2010, 07:09 AM
Hi. Got a question about a shifter I got from a junkyard for my conversion to an auto trans from a standard. Shifter was from an old mustang but I am not sure. It looks like one from 64 mustang? The problem, is the shifter has no detent from reverse to drive, It looks like a detent was never designed into it. Does anyone know if this was common and will it still be alright for my conversion. I can put a detent in it by fabrication. but was wondering if anyone can shed light on this situation. Thanks
Old 10-23-2010, 07:58 PM
junior stocker's Avatar
Just be sure to match the trans lever, to the shifter lever, center-to-center length, or at least have the geometry correct (1:1, 2:1, etc), then fab up the correct detents for the shifter to match the trans so it works smoothly. I've seen these Mustang/Pinto type floor shifters used for many different installs.
700R4 conversion for a 56 chev 265 hrjme Transmission - Rearend 1 07-06-2007 04:53 AM
Chev truck 4 speed shifter fix? pic MM in NM Transmission - Rearend 2 05-19-2006 06:21 PM
Chev 3 spd auto Sandman Transmission - Rearend 2 05-28-2002 01:50 AM
Changing to an auto from manual in 57 Chev pikalpha Transmission - Rearend 3 12-14-2001 05:30 AM
Turbo 350 Trans in '63 Chev p/u Freedo Transmission - Rearend 1 09-04-2001 07:59 AM
