56 chev. drum to disc? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2010, 05:59 PM
question on changing from drum to disc brakes on front. Was planning to buy kit on ebay that comes as a kit using my spindles. The kit has no master cyl.
with it. What would I get as a master cyl. as I assume the small stock one is no good after conv. Do I also need a porportioning valve, etc. ? Not sure I`m saying that right. Any help appreciated. Thanks
Old 11-12-2010, 08:39 PM
Semper Gumby
Wiki Edits: 2
56 Chev disc brakes
Mine is a '57 Chev - same brake system as stock.
Not sure which kit you are looking at - I installed a Superbell kit, using my stock spindles
After mucho searching I found that the master cyl from a mid 70's Montecarlo/Grandprix etc worked perfectly, along with the booster from a '83 Firechicken which had exactly the right bolt spacing to fit my firewall replacing where the stock master had been. Had to make up a custom rod from booster to master to make it all work. And yes, I use the proportioning valve from the same Monte C I pirated the M/C from.
Old 11-13-2010, 06:52 AM
thanks for the info Dave, however I was hoping all I need is a master cyl. and porportioning valve, and have that do a decent job of stopping. By the way is the valve sometimes called a distribution valve? The wrecking yards around here dont have much of anything, so will have to go to Checker or napa etc. thats why I was hoping for an mc that I could buy from one of them that would have a matching bolt pattern on my firewall. Thanks
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 02:07 PM
Weight of Disc Brakes vs Drum Brakes leejoy Suspension - Brakes - Steering 7 06-29-2007 12:41 AM
1971 Nova rear drum to disc conversion. 1971 Nova Suspension - Brakes - Steering 5 12-12-2006 03:07 PM
Converting 54 Chev front brakes to disc jpd37 Suspension - Brakes - Steering 2 05-28-2005 12:25 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
