-   -   56 chev. rear end gear picture? (http://www.hotrodders.com/forum/56-chev-rear-end-gear-picture-191205.html)
db flyer 01-22-2011 05:32 PM
can someone pull up a picture of 3rd mimber showings the gears in including pinion and assc. gears non positraction for my 56 chev. I purchased a used 3rd member and think something is missing. Hope I`m wrong. Thanks
matts37chev 01-22-2011 06:11 PM
i'm guessing it would be easier if you post a pic of what you got, and we'll let you know if we see anything missing.
what do you think is not there?
db flyer 01-22-2011 06:56 PM
1`ll see if i can put on a pic, but i wonder why there is not 2 gears on the shaft between the gears that are on ends of axles. i know this is dumb on my part, but the gears on end of axles right now are floating and looks to me that they will hit the center pin?
big gear head 01-22-2011 07:05 PM
There should be at least 4 gears inside the differential. If the axle gears are the only thing in it then the pinion gears are missing. Probably broke and didn't get replaced.
db flyer 01-22-2011 07:18 PM
the pinion and ring gear are in place but the center section on has 2 gears on end of axles.
poncho62 01-22-2011 07:25 PM
2 spider gears are missing
poncho62 01-22-2011 07:30 PM
This is not a 56 rear, but gives you the idea
http://www.quadratec.com/Assets/Know...e/opendiff.jpg
db flyer 01-22-2011 07:59 PM
Thanks Poncho that is exactly what I bought, it is supposedly from a 59 Impala. I am missing the 2 spider gears from the cross pin. Do you or anyone else know if my 2 spider gears will work in there? By my measurements it looks like they will. Thanks
big gear head 01-22-2011 08:32 PM
Give it a try. All you have to loose is some time.
68NovaSS 01-22-2011 10:20 PM
What Big said. You can install them and be able to tell it if will at least rotate OK out of the housing.
