56 chev. rear end gear picture? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2011, 06:32 PM
can someone pull up a picture of 3rd mimber showings the gears in including pinion and assc. gears non positraction for my 56 chev. I purchased a used 3rd member and think something is missing. Hope I`m wrong. Thanks
Old 01-22-2011, 07:11 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i'm guessing it would be easier if you post a pic of what you got, and we'll let you know if we see anything missing.
what do you think is not there?
Old 01-22-2011, 07:56 PM
1`ll see if i can put on a pic, but i wonder why there is not 2 gears on the shaft between the gears that are on ends of axles. i know this is dumb on my part, but the gears on end of axles right now are floating and looks to me that they will hit the center pin?
Old 01-22-2011, 08:05 PM
big gear head's Avatar
High Performance Rear Ends
There should be at least 4 gears inside the differential. If the axle gears are the only thing in it then the pinion gears are missing. Probably broke and didn't get replaced.
Old 01-22-2011, 08:18 PM
the pinion and ring gear are in place but the center section on has 2 gears on end of axles.
Old 01-22-2011, 08:25 PM
poncho62's Avatar
Wiki Edits: 5
2 spider gears are missing
Old 01-22-2011, 08:30 PM
poncho62's Avatar
Wiki Edits: 5
This is not a 56 rear, but gives you the idea
Old 01-22-2011, 08:59 PM
Thanks Poncho that is exactly what I bought, it is supposedly from a 59 Impala. I am missing the 2 spider gears from the cross pin. Do you or anyone else know if my 2 spider gears will work in there? By my measurements it looks like they will. Thanks
Old 01-22-2011, 09:32 PM
Give it a try. All you have to loose is some time.
Old 01-22-2011, 11:20 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What Big said. You can install them and be able to tell it if will at least rotate OK out of the housing.
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 12:32 PM
chev 261 crankshaft gear Macman Engine 0 08-22-2004 06:11 PM
rebuild chev 261: timing gear marks? Macman Engine 1 07-27-2004 01:14 PM
Rear gear choice, Gear to Tow icegnome Transmission - Rearend 3 12-03-2002 08:17 AM
Installing a chev small block in the rear of an chev s-10 vegadeth Body - Exterior 11 07-16-2002 04:16 PM
