56 chev rear springs left to right.??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2007, 07:29 PM
does anyone know how I can switch springs to the inside of frame without using spring pockets. I saw this onetime but I cant remember where, He also had A crossmember to bolt his rear shocks to. Thank you retired 56
Old 10-30-2007, 08:31 AM
31 five window
Last journal entry: Moving along with patch panels.
I dont know how far you want to go but Itubbed my 57 chevy and cut the frame rails in front of spring perch and at rear cross member then swapped sides.I butted the inside of the rails which moved them in 4 inches and boxed them at a 45 angle with 1/8 plate and welded rear back to cross member in proper alienment. this gave me 8 inches more tire clearance because of the frame width and the springs being inboard.I was able to run 31x18.50s with ease. I also used 2x2 tubing to make shock mounts between frame rails.
rear springs daveshoby Transmission - Rearend 0 07-16-2007 09:35 PM
rear leaf springs ko.17 Suspension - Brakes - Steering 4 09-28-2005 03:14 PM
'38 chevy rear springs TheCiscoKid Suspension - Brakes - Steering 7 09-25-2005 11:52 AM
rear four link on 56 chev stepside 56 3100 Suspension - Brakes - Steering 14 03-15-2005 02:10 PM
Installing a chev small block in the rear of an chev s-10 vegadeth Body - Exterior 11 07-16-2002 03:16 PM
