#1
56 chevy 3 speed, what is it?
can anyone tell me if the three on the tree in my 56 is a powerglide transmission? if not what else could it be? I do not have access to the car right now so I can't look at it.
Register now (free) or login to remove ads |
#2
"Three on the tree" usually denotes a manual trans.
#4
Usually a Saginaw transmission.
#5
FYI, A Powerglide is a 2 speed auto. |
#6
thanks for your help, I'm pretty much knowledgeless ( is that a word? ) when it comes to transmission stuff. I did notice that one of the bolt ears on the tail shaft assembly is broken off. Is this transmission capeable of handling BB power 400-500 hp. Is it worth rebuilding or should I just go with a turbo 400?
#7
You seem mixed up? Does your car have a clutch pedal?
#10
I think those cars used the old light-duty Muncie 3-speed, with the 4-bolt side cover and the non-synchronized low gear. Saginaws didn't come along until '66 or so.
Unless somebody changed something on it in the last 50 years. |
#11
I think it is probably the same one that came in the car. If it is the muncie I would guess that it would be buildable to handle bb power. I've never rebuilt a transmission but I have installed a few so this will be a learning experience. What should I look for as far as tolerances on the muncie?
#12
If this trans has a four bolt side cover it would not hold up to the 270hp 283ci. let alone any engine with some serious torque.
| Thread Tools | Search this Thread |
| Similar Threads for: "56 chevy 3 speed, what is it?" | ||||
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| Engine build ideas | Rug | Engine | 23 | 12-25-2006 01:39 PM |
| LS1 Radiator in 56 Chevy | snimmo | Engine | 8 | 10-22-2005 05:44 PM |
| Richmond 5 speed, 56 Chevy and shifter | 56classic | Transmission - Rearend | 3 | 08-28-2005 08:00 PM |
| '56 Chevy wagon in Northwest Indiana | oldstreetrodder | Introduce Yourself | 1 | 08-12-2005 05:09 PM |
