56 chevy clutch linkage clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2005, 08:45 AM
56 chevy just swaped out the stright 6 to a 350 now the exust manifolds are in the way of the piviot for the the clutch linkage would headers solve the problem or and thoughts would be nice thanks
Old 04-25-2005, 08:50 AM
MI2600's Avatar
Member# 3287
Are you using rams horns manifolds? If you're using a rear dump manifold of older vintage, you'll have to change them out.
Old 04-25-2005, 10:52 AM
broncoII88's Avatar
Do the right thing...
You might be able to use shorty headers, then make the y pipe clear the linkage. Block hugger headers might get in the way anyway instead of solving the problem. You can usually pick up a set of corvette rams horn manifolds at a junkyard or swap meet for pretty cheap. They actually flow pretty good too for cast iron!
whats the difference between 55 and 56 chevy pickup? mile-hightoyz Hotrodding Basics 8 08-13-2011 10:33 AM
Model A Tinker Toy clutch linkage ? Mickey Miller Transmission - Rearend 2 08-09-2005 04:34 PM
Firebird and Camaro clutch linkage BanditT/A Transmission - Rearend 1 10-25-2004 10:13 PM
TH 350 Intermediate clutch clearance 1969Chevelle Transmission - Rearend 1 08-26-2003 05:34 PM
Side mounts on a 56 chevy onelac Engine 0 10-13-2002 09:00 AM
