56 Chevy pickup 3200 drive line Vibration - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2010, 10:20 AM
I just bought a 56 Chevy pickup 3200 and am starting to restore it. I got the motor running great and when I went to test drive it I found that I have a really bad vibration. It was sitting in a field for 10 years before I bought it but the guy I bought it from is a good old boy and said he was driving it right up till the day he parked it. I blocked the rear tires up and ran it in gear and the drive shafts are straight. It is not the motor because when its in neutral it has no vibration at any rmp. It is a manual 4 speed on the floor. I on can go about 8 - 10 mph and then after that it starts shacking the truck very very bad and the clutch pedal starts jumping up and down. ????? Any body out there have any idea what I am dealing with ...Sincerely Dave
Old 06-02-2010, 10:44 AM
Rusted u-joint?
Old 06-02-2010, 10:58 AM
big gear head's Avatar
High Performance Rear Ends
Does it have a carrier bearing on the drive shaft? If it does then it probably needs to be replaced. The rubber around the bearing is probably rotted.
Old 06-02-2010, 11:00 AM
That'd be my guess too. Hanger bearing
Old 06-02-2010, 12:09 PM
Yes it does..thank you , I will change it out tonight....Dave
56 chevy vibration at 55mph and up oldchevy1956 General Rodding Tech 9 07-10-2010 10:00 AM
Upgrade Ford 4 flat-head drive line with V8 drive line up to 1937 (mechanical brake) roundhousedog Transmission - Rearend 0 07-23-2009 05:29 PM
Body Line Man586 Body - Exterior 6 08-20-2004 09:24 AM
56 Chevy Pickup Grill swap Hairy Body - Exterior 6 11-20-2003 02:33 PM
Rodded 56 Chevy Pickup denbeighk Hotrodders' Lounge 2 01-14-2002 12:19 PM
