56 Chevy Qa1 Suspension Ride Height Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2006, 01:12 PM
I am restoring a 56 chevy sedan. Estimated weight will be anywhere from 3700 to 4000lbs. I am installing QA1 Drag race adjustable coilovers rated for 4000lb vehicles. I am setting up my vehicle at a specific ground clearance but won't have the weight of the vehicle on the suspension to find out what my actual ground clearance will be. For example, if I'm setting my vehicle and all suspension up for 4" ground clearance, after there's actual over all weight of the vehicle on the suspension, what will be my ground clearance be now? How much more will it drop?
Old 02-08-2006, 05:06 PM
there is an installed height for the shocks...distance between upper and lower mounting points...fab mounts to that distance...when vehicle is done, adjust spring adjusters to achieve that same measurement. if you cant get that same measurement, you will need to go to a different spring rate. ground clearance will still be the same as long as you have figured in actual axle center lines due to tire squish when loaded.
Make sense?.....let me know if you need more help
Dave M.
Ride height delimma wally8 Suspension - Brakes - Steering 8 01-03-2005 02:15 AM
66 Impala suspension question black66 Suspension - Brakes - Steering 4 07-04-2004 08:42 PM
1962 chevy pick up nedds suspension help manoso Suspension - Brakes - Steering 0 05-24-2004 09:23 AM
56 chevy rear disc brakes 56-210 Suspension - Brakes - Steering 4 10-08-2003 08:13 PM
question: re-chrome 56 chevy taillights sglig Body - Exterior 10 03-23-2003 08:43 PM
