56 chevy truck front springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2008, 11:09 AM
i have a 56 chevy truck, with a camaro front clip. the car is very soft when you bounce the front. i can spring the front up and down a good 8 inches by hand. shockers are working fine.but the springs seem way to light. they have lifter knuckles between two coils. what spring would you recommend and where can i get them. i from the uk so a large international company would be great.could i use stock camaro and cut them down
Old 01-24-2008, 03:55 PM
AntnyL's Avatar
Brit,
I'd look for a new set of Moog springs for whatever year Camaro clip you have. Cut a coil or 2 off to get the ride height that you want. Sounds like your springs are wrong for that clip, or just plain tired. The fact that you have lift knuckles tells me the springs might be tired, and were given a "boost" with those knuckles.
Old 01-24-2008, 04:09 PM
poncho62's Avatar
Wiki Edits: 5
Yes...if there are spacers, the springs are beat..........I would still question the shocks too if you can bounce it that easy.
Old 01-25-2008, 04:49 PM
Chopt 48's Avatar
It sounds like someone has put light weight springs in it. Possibly drag car springs. I have to agree with Poncho in that I really question the condition of the shocks. If you quickly put weight on the bumper and back off the front end shouldn't bounce more than once or twice at the most before coming to rest.
Old 01-25-2008, 05:41 PM
front springs
thanks for the feed back i have ordered a pair of stock sbc camaro springs and new shocks. that should sort it. shocks only bounce once but i will change them as well
Old 02-12-2008, 02:05 PM
just fitted new springs and shockers great job fitted stock camaro front springs the truck sits about 1 inch higher. both front springs were broken one coil and the shocker were drag shocks. thanks for the help
55 chevy truck front suspension mec123 Introduce Yourself 6 11-17-2011 12:46 PM
Mustang 2 Front end on a 55 Chevy truck? Slickriffs Suspension - Brakes - Steering 14 11-10-2010 06:10 PM
56 chevy truck 6 lug wheels?? hottrodz General Rodding Tech 5 10-06-2007 05:46 PM
56 chevy truck frame swap kid Suspension - Brakes - Steering 3 08-06-2006 05:45 PM
