Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 07-18-2007, 08:46 PM
oldchevy1956 oldchevy1956 is offline
56 chevy vibration at 55mph and up
I have restored a 56 chevy and put in a 700r4 transmission and I have rebuilt/ replaced everything including front bushings, rear leaf spring bushings, shocks, put disk brakes on the front, put rack and pinion steering, installed front and rear sway bars, new u-joints and balanced driveshaft, new wheels and tires, etc and I still have a vibration at 55 mph and up. I can shift into neutral at highway speeds and I still have the vibration. Any ideas where else to look. This is driving me craze almost like the poison ivy I have right now.
Old 07-18-2007, 10:00 PM
scholman scholman is offline
re: 56 chevy vibration at 55mph and up
oldchevy56,
Take a look at the rear U-joint to be sure it is centered in the pinion yoke.
Also with all the new and "up-graded" items in the powertrain double check the alignment of the output shaft of the transmission and the pinion angle of the rear end.
Good Luck
Old 07-19-2007, 06:17 AM
302 Z28's Avatar
302 Z28 302 Z28 is online now
Moderator
Pinion bearings .
Vince
Here's to you DoC, you will always be here.
My project 34
http://www.hotrodders.com/forum/34-...ght=34+progress
Old 07-19-2007, 09:10 AM
I will be looking at the rear end more closely as this is the one area that I have not rebuilt. I also am thinking about lowering the rear transmission 3/4in to provide a straight angle for the driveshaft.
Old 07-20-2007, 06:30 AM
oldchevy1956,
The output shaft of the transmission needs to be Parallel with the pinion of the rear end not in a straight line.
Scholman
Old 07-22-2007, 07:20 AM
I found that the transmission was too high. I lowered the transmission 2 inches and this became parallel with the rear end which still gave a slight slope of the driveshaft. I went for a test drive and the vibration was gone at all speeds even up to over 80 mph.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
