56 engine swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2002, 10:19 PM
Question 56 engine swap
i want to change out th old 6 cylinder out of my 56 belair for a small block chevy v8 any info would be great what are the steps to getting this done motor mounts ect.thank you
Old 05-15-2002, 08:08 AM
New Member
Talking
'56 came with a 283 as an option so the motor mounts should be available through a reproduction parts outfit. everything else should fall into place. i used old chevy ('64) motor mounts (frame and engine sides) and just drilled the crossmember for a th-350 rubber mount. still works great to this day. if you want to do this you'll have to cut the frame side mounts down some and weld them in. i should mention that they were 1964 chevy pickup truck mounts.
[ May 15, 2002: Message edited by: middspecauto ]</p>
