'56 F100 antenna - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2011, 07:58 PM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
'56 F100 antenna
Not sure if this should go here or under General tech, so moderators help me out On a Ford Truck site I've been posting queries about radio antennas. My truck's mounting hole is on the passenger side of the cowl and is cut at about a 45 degree angle. The universal one that "adjust to 35 degrees" still left it cocked out more than I like. Since the ones I've found that are specific to that area on my truck are $60, I decided to look for alternatives. After opening and returning about 5 to various auto parts stores, I found one that suits my taste for my Panel truck. It is a shorter rubber one. The adjustment is on the antenna bottom and not the base mount. I've include a couple of pics for any others that have a similar situation. This antenna cost me about $19 dollars at Best Buy. It is made by Metra and is in their AntennaWorks series. The number is 44-US07R. Written on the package is Top/Side mount for 1"/25mm hole. My hole is about 1" x 1.25" and is completely covered. It's not for the purists, but hopefully gives another option to those on a quest for the lowly antenna Thanks for your time,
James
Name:	sep 23, 2011 001.JPG
ID:	58515   Click image for larger version
Name:	sep 23, 2011 002.JPG
ID:	58516   Click image for larger version
Name:	sep 23, 2011 003.JPG
ID:	58517   Click image for larger version
Name:	sep 23, 2011 004.JPG
ID:	58518   Click image for larger version
Name:	sep 23, 2011 005.JPG
Old 09-23-2011, 08:52 AM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
I think I'd plug that hole and get a hidden antena under the dash. Or recess the hole and go power. Just my .02.
Old 09-23-2011, 08:57 AM
Hwyhogg's Avatar
good ideas; however, I will eventually use this mounting point for one of the "disquised" cb antennas and go with the underdash radio antenna,
thanks
Old 09-23-2011, 12:38 PM
ogre's Avatar
the 'Duracell Project'
i bought a $5 fm antennae and mounted it under the truck, it works fine.
power antenna damon.davey Electrical 3 06-01-2011 03:54 PM
antenna mast mitmaks General Rodding Tech 1 04-05-2011 09:54 PM
67 camaro antenna eastvandan Introduce Yourself 2 04-26-2006 06:49 PM
drilling for an antenna red_rider52 Body - Exterior 3 03-26-2006 01:50 AM
Hidden antenna BigMac Electrical 10 11-11-2003 05:34 PM
