56 merc power disc brake swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2011, 11:51 AM
My dad and I were building our car before he passed from cancer last October. He purcjased a 4 wheel power disc brake kit from Direct Fit Brakes (no longer in business),so I have no tech help. I have everything mounted,and all the brake lines fabed and installed, but I cant get fluid from calipers when bleeding. I have fluid from the lines,but have no idea why I cant get them to bleed out through calipers. I thought rewiring the entire car was going to be tough. That's proving to be less aggrevating than the brakes. Any insite would really help. Thanx.
Old 11-29-2011, 12:00 PM
life is a temporary assignment
Did you bench bleed the master cylinder ???
Old 12-01-2011, 02:17 PM
Yes, I did bench bleed the master. I even tried using a mighty vac hand pump. I wish I could just take it to a brake shop,but money is tight,and my dad was a retired body man before his passing.( he didn't exactly have an impressive portfolio to leave behind.)
Old 12-03-2011, 03:29 PM
venturesomerite's Avatar
I recently had to bleed brakes on bike that had sat for years, I couldn't get fluid out with a vac, so I ended up using a piece of plate steel that was around, drilled and tapped an air line fitting into it with a regulator and cut a piece of rubber with a hole in it to go under it. I just used some clamps to clamp it on the master in place of the regular cover, and the extra pressue pushed the fluid through the lines in no time. Just don't use too much pressure, I used about 10-20 lbs. Worked great and was free.
Old 12-15-2011, 02:13 PM
Thanx for the idea ! I'll give it a try.
Power Disc Brakes vs. Brake booster allclassicsbefore70 Suspension - Brakes - Steering 5 09-24-2011 02:08 PM
Ford Disc Brake swap visiong Suspension - Brakes - Steering 1 04-15-2009 07:20 AM
? On Granada disc brake swap Fairlane Man Suspension - Brakes - Steering 14 12-08-2007 11:28 AM
3rd Gen disc brake swap Camaro2Fast4u Suspension - Brakes - Steering 1 07-07-2003 05:25 AM
68 Chevy II disc brake swap krangar Suspension - Brakes - Steering 1 01-26-2003 06:11 AM
