56 Olds Rear End Tear Down - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2011, 07:55 AM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
I have a rear axle from a 56 Olds that has a stuck center section. The wheels turn when there is no load on them but it will not turn with the weight of the car on them.
I have pulled the axle assy out and would like to remove the center section to see/fix the problem.
What is the process for removing the center section? It appears the axles have to come out first. How do the axles come out?
Old 05-10-2011, 10:15 AM
The axles are held in with four bols on the housing at the brake backing plate.Remove them and the axle slides out.
After axles are out then remove the diff.gears.
Old 05-10-2011, 07:08 PM
olds rear
mark williams still has parts for early olds/pontiac rears
Old 05-10-2011, 08:42 PM
willowbilly3's Avatar
Last journal entry: Body mods
I just got a job today changing the 3rd member in a 56 Olds. He has a junkyard one that I need to pull apart and check over, then install. Thanks for the info on where to get parts.
Old 05-10-2011, 10:46 PM
bty back in the day that was the rear of choice like the ford 9in is today.they were strong and better than a 12 bolt.had one in my 55 chevy with 557 gears a nd one in my big block anglia with 488 gears never had a problem with them they can handle a good amount of power
56/57 olds rear k-star Transmission - Rearend 8 01-18-2007 05:11 AM
40 Olds rear end nomaddaddy Transmission - Rearend 1 07-14-2005 06:21 AM
Olds Rear End KRZEMIEN Transmission - Rearend 3 12-07-2004 06:28 AM
Olds Rear End KRZEMIEN Introduce Yourself 2 12-06-2004 03:44 PM
'56 Olds rear end willys36@aol.com Transmission - Rearend 6 03-06-2003 03:16 PM
