Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 56 powerglide
Thread: 56 powerglide
Old 08-31-2003, 08:19 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Cool
Originally posted by jimfulco
I think the guts are different. The iron PG had a rear pump, while the aluminum one does not.
the internals are different......Some Look the same but different enough to cause some troubles. We fixed a Iron glide last year that had aluminum glide drum in it. This iron glide had this goofy ratcheting noise when put into park while sitin still. We thought was the park pawl. It was the drum spacing & end play problem
Yes , the early aluminum power glides had rear pumps. If the rear pump sheared the drive pin it would not up shift as I recall.
The rear pump was eliminated after 1967. I had a 67 Camaro that would not upshift after an over haul. The tranny builder had not installed the drive key for the pump gear in the rear pump. I ain't naming names here....
I gotta sign this too?
Tony
