-   -   56 SBC cam lift question (http://www.hotrodders.com/forum/56-sbc-cam-lift-question-87678.html)
kohle1ce 04-23-2006 09:10 PM
Thanks for your time ahead of time everyone.
I have a 1956 265 block that is bored to a 283. I have dome top pistons, which measure about .131". I have a .490 intake and .510 exhaust on my cam. I did a clay test for clearance and there was no clay left between them. Does anybody have a idea on what size cam I should run? Tri-Five guys please help me out. My bore is a 3.875" and my stroke is 3"
Thanks again!
dgcantrellsr 04-24-2006 11:19 AM
Thanks again!
You will need at least .085-.100 clearance on the piston to valve. Either cut piston reliefs or get a smaller lift cam.
And you are saying you punched a 265 (3.750 bore) to a 283 (3.875 bore)?
kohle1ce 04-25-2006 12:46 AM
Thanks for the suggestion. I solved the problem. Come to find out I had the timing off between the crank and cam. oops. But yes it was a 265 the block number is 3720991 dated to 1956, as far as I know.
