56 slammed on a s10 frame need advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2014, 12:17 PM
Hi I have a 56 dodge truck sitting on a s10 frame. Need advice on rear ends. Have stock 10bolt non posi want to beef it up. Only have a 350 in it with turbo400. But I am building a 426hemi need something strong enough. Any suggestions thanks.
Old 01-18-2014, 06:39 PM
life is a temporary assignment
I like to use 9'' ford rear ends.. Never let me down..
Old 01-18-2014, 06:49 PM
techinspector1's Avatar
Wiki Edits: 326
In my entire life, I have seen only one 9" rear fragged. It was in a Nostalgia Funny car. I don't know how much power the motor was makin', but I'd guess 1800/2000 hp on alcohol.
Old 01-18-2014, 06:55 PM
9" fords are called bulletproof for a reason.
Old 01-18-2014, 07:08 PM
Even the Ford 8.8" is supposed to be comparable to the GM 12 bolt. It would be a step up from the 10 bolt that you are currently using. Plus you can get them with rear disc brakes, posi traction and the majority of them had 3.73 gears.
Experienced painters advice please! Advice on painting a frame El Campo Hotrodding Basics 25 03-13-2012 03:21 PM
S10 frame help. matt167 Suspension - Brakes - Steering 15 07-28-2006 07:10 PM
S10 pickup or S10 Blazer frame? raj4851 Hotrodding Basics 10 01-06-2006 09:28 PM
S10 frame to what? raj4851 General Rodding Tech 3 12-19-2005 07:21 AM
