56 T Bird Help
Hey gang, the latest project in the shop is a 56 Thunderbird. This is more of a restoration than hotrod, but knowing there is a lot of expertise on this board, I bring my problem. We need to remove the dash and to get it out, we have to drop the steering column. There are 4 small screws that need to be removed, but the collar around the tube is blocking it. My question is, how do you go about removing the collars from the steering wheel to the dash???? We do not have a manual, but do have the parts detail that shows alll the parts.
Trees |
Jack, that sounds good. We thought we may have to pull the upper shaft, wheel and all but were not sure. I would appreciate the picture!!
Trees |
Trees, I sent you the picture but after reading I'm not sure if its for the Bird or Ford. Hope they are simular and it will help.
Sorry about the first picture, picked the wrong one. Thats a 36 Adler I'm thinking of making a hot rod out of, like I don't have enough projects. Jack |
Jack, received both, printed out and have at the shop. Will help!!
Thanks Trees |
Those early T-Birds have a adjustable column. If you turn the knurled looking part of the column,the steering wheel can be pulled toward the driver. ( don't remember if it is cw or ccw).And you can easily get to the screws.
Thanks, Boomer. That makes sense and explains the big chrome section. We are on hold right now, fixing up the old barn to store some of our toys. Getting a little old for putting in ceiling panels and doing concrete work!!
Trees |
