Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 5600 rpm stutter
  #54 (permalink)
Old 11-25-2010, 05:59 PM
Duntov's Avatar
Duntov Duntov is offline
Visit the NASCAR Hall of Fame
I was referencing flywheel HP without thinking
Originally Posted by wadedog
I have a victor jr intake, they did put on a 4 hole 1" spacer on it now.
I don't have a degree wheel .
the cam was installed straight up and i'm and hoping it is the right cam and not wrong cam in the right box.
You know what, my son reminded me earlier that the horsepower readings I got when I ran your combo on my DynoSim are at the flywheel........ At the rear wheels it could be 40% lower.. Does it run strong?
I've built that exact combo before and had it on file. 200 RHS heads, same cam, even had the Victor Jr. Very strong combo. Think it ran in the upper 12s and was still good on the street. Customer did go back to dual plane after he drove it around for a while. Picked up some bottom end for that.
Skip White likes that combo but pushes his PC heads with it.. If you find one of his Pro Comp head listings on Ebay it will have a long page with some various specs You Tube Videos of his ZCar running different combos he builds. One of them is close to yours. May have some ETs to compare..
Maybe it's not as far off as I thought.
