57-58 olds intake/edmunds - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2008, 07:31 PM
Just got a Edmunds 2x2 intake in a trade and believe it is for a 57-58 olds.Any other years that it will fit?Any way to tell what it is for?no part number on it but there is a "B" cast in the bottom.I tried to post a picture but keep saying the file is too big
Old 07-17-2008, 07:47 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
To the best of my knowledge, Edmunds only made 2x2 olds for the 49 to 53 303. There are 2 different castings that I have seen. Totally different in style. The earlier one is marked olds-49-53 underneath. The later is not marked.
I will put up pics of both asap.
by the way, these 2 will not fit even the 324 unless you make adapter plates to cover the larger 324 ports on the heads.
Old 07-17-2008, 08:32 PM
F&J F&J is offline
Here is an early Edmunds 2x2 for 49-53 303 olds. This was designed to use the early stock olds sidedraft carb(s). Most people ran the Stromberg AAV-26 carbs instead, that came on 40s cars like Stude, Cad, as well as the twin AAV-26s used on the factory dual carb Buick inline 8.
You may notice that the Edmunds logo is done in cursive script. The later casting has non-cursive lettering, as well as a totally different looking casting that sits higher.
Here is the early manifold using homemade aluminum spacer/adapters to be able to fit the larger ports. I don't recall exactly what year this motor is, I believe the owner said it was a 371. I can't quite make out the 2 digit casting number on the head, center port. It appears to be a 14, so it is a bigger motor that the 56 324 which used #10 heads.
The reason you need spacers is: The port size on the 303 is very small. The bolt patterns are the same on 49-to-56 at least, but the 324 & larger heads have a port that won't completely be covered by the 303 casting. So you make flat plates to cover the mismatch. I am not sure if the 49-56 bolt pattern is the same on 57-58; I did try to measure a 57-58 stock J-2 tripower manifold at a swap, and I "think" it measured out Ok.
I'll try to find where I put the pics of the later Edmunds 2x2.
Old 07-17-2008, 08:42 PM
F&J F&J is offline
Here is the later 303 casting. Note there is no open webbing between the runners like the early one, as well as the different style of lettering.
PM me if you plan on ebaying it, if it is this later style. I already have the earlier one.
Old 07-18-2008, 06:42 AM
same
Yup,mine looks like the first picture,the one with the open web.Was kinda hoping I could of used it on my 38 ford pickup that I am going to start getting parts for(gotta finish the 46 dodge pickup first)Maybe I will start looking for a earlier olds motor.Thanks much for the info and pictures
Old 07-18-2008, 07:41 PM
same
Went out and looked at mine again and it looks like the second picture for the "newer"motor.has the solid base and has "EDMUNDS" with "CUSTOM" under it so I am thinking it is for the later motor.I did get a picture uploaded in my photo album
Old 07-20-2008, 12:53 PM
same?
F&J,did you get a chance to look at my picture?
Old 07-20-2008, 01:15 PM
F&J F&J is offline
Yes, I missed it till just now
Sure looks like the later 303 OLDS. The manifold appears to be OLDS, due to the shape of the front water crossover as well as those two upright bosses for ther olds power steering bracket.
The only motor for a true bolt-on with no mods, is the 303 from 49-53. Adapter plates are needed for 324 & larger motors. The internal port runners inside the manifold will also be smaller than 324 & bigger, but if you are not after super high RPM flow, don't worry about the runner size.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
'57 283 into '58 and later GM cars DHMag Hotrodding Basics 2 07-05-2005 06:04 AM
frame swap for '57 olds wagon chopperimpala Suspension - Brakes - Steering 11 04-10-2005 11:07 PM
57 olds 98 disc brake conversion? Donor? murrsue Suspension - Brakes - Steering 2 04-01-2005 03:50 PM
57 Olds disks Kurt Suspension - Brakes - Steering 8 11-30-2004 01:50 PM
