57 bel air no spark to plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2008, 07:16 PM
i have replaced the dash and engine harness, ballast, coil, distibutor's condensor, spark plug wires. I have also caged the contacts in distributor.
Here is what has been tested on a full battery:
The reading between ign coil and ground is 12v with "points open", the reading with "points closed" is 12v. the reading at the distributor "points closed" is 12v as well. The reading at the ballast and ground are well under 1v with "points closed". The ballast ohms out with in range. All wires are correct and everything in car has power.
Please Help this is the only thing holding the car down, i've been over all the wires many times.
Old 07-12-2008, 07:55 AM
sounds like your points are not adjusted correctly or there is an open in the wire from the coil to the points.With points closed voltage on meter should be very low.a quick check is a test light on negative terminal of coil ignition on points open light should light, points closed light should not light.Also you should install a ballast or coil with internal resistor so that voltage at coil is about 8 volts any higher will fry points and coil.
Old 07-12-2008, 09:04 AM
T-bucket23's Avatar
Wiki Edits: 26
Originally Posted by R3V3N57
i have replaced the dash and engine harness, ballast, coil, distributor's condenser, spark plug wires. I have also caged the contacts in distributor.
If your first test is at the + side of the coil, that is correct. The second set of readings is wrong. The points are not closing or the contacts have something on them. The points are screwed to the plate of the dist which is connected to the stationary point and ground. When the points are closed the neg side of the coil or at the points (same thing) there should be 0 voltage.
I have a complete WIKI article on this
Wiki Article
Chet
Old 07-14-2008, 03:57 PM
Thank you very much
Thanks yall, i did replace the points on sunday and it worked, i had gaged the points before and everything is correctly done by the book. Thank you for you help. I had gone through the troubleshooting steps from the shop manual a few times, and the points showed up to be a problem in more than one catagory. we were all right.
now on to bigger and better things.
respirators and supplied air robs ss Body - Exterior 12 08-30-2006 07:44 PM
57 Bel Air Wheel clearance Question... TheHaloEra Suspension - Brakes - Steering 3 06-01-2006 01:31 PM
'57 BEl air wagon trim mitmaks Body - Exterior 9 03-26-2003 11:26 PM
'57 bel air paint mitmaks Body - Exterior 3 12-06-2002 10:23 AM
'57 Bel air paint mitmaks Body - Exterior 2 11-16-2002 06:42 PM
