A 57 Cadillac I picked up - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2010, 10:34 PM
K and K's Avatar
Last journal entry: Original 365
Just picked this up last night, spent the day today getting it running and rollable. Still alot more to be done. Motor is supposed to be original 365"
Never built a Caddy before but this the year I always wanted.
Old 07-31-2010, 10:46 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That car is in pretty decent condition- a "survivor", looks like!
Makes me think to just detail it out all you can and keep it original as possible. Paint is gone, though, but still has the dagmars on the front bumper!
What are your plans for it? And, welcome aboard.
Old 07-31-2010, 11:17 PM
K and K's Avatar
Thanks for having me! I have been a member on a Camaro forum for my 67' I've owned for almost fifteen years but man do I miss rodding!
For this car for the moment I need to get it streetable. The previous owner bought it as is and it sat it his garage for about five years. The owner before him slammed it by cutting front springs and blocks in the rear. The owner I bought it from pulled the rear lowering blocks but then left it as is without tightening down the u-bolts so the rear end is literally "floating" in mid air above the leaf/shock mount plates. Fuel line at carb becomes empty shortly after engine is turned off. Alternator isnt mounted right, not wired up, wiring throughout is jacked up. Lights dont work.
But original power windows and seats all work.
I want to (aside from make streetable) keep interior original looking, refresh engine in the compartment for now, then pull it in the winter depending on how far I get on the Scout II Im building for the wife!
Old 08-01-2010, 10:24 AM
Because this thread has NO technical merit ( so far ) as a Moderator I moved it the the BASIC area.
Neat Cadillac. I have always like those but have never found a decent one at a price I thought reasonable. Caddys bring big BUCKS $$$ in my area.
Deuce ... Moderator
Old 08-01-2010, 10:46 AM
Yeah, cool cars that is for sure. Americana in the fifties at its best!
Old 08-01-2010, 09:14 PM
K and K's Avatar
Thanks guys! Yeah I'm stoked. It fills a void I've had with my cars for a long time! And thank you Mr. Martin Sr. A couple years ago you set me on the right path on the TeamCamaro site and I have been greatful ever since.
Thanks mods for moving this where it fit best.
Old 09-05-2010, 11:29 PM
K and K's Avatar
Some updates on a couple things I've found on the car since. Nothing unusual for an old car, but some that make you think twice before you put anyone you care about in an old car. I have'nt even scratched below the surface of the car either, just trying to enjoy some cruising with it before the Northern California rain comes.
Here is a thread I started on just peeking into the engine: Pearing into an original 57' Cadillac 365
When old tires are inflated to 32psi and then driven on a 107 degree day:
[IMG][/IMG]
Lower ball joint bolted on with one bolt...instead of four:
[IMG][/IMG]
Old 09-17-2010, 10:04 PM
K and K's Avatar
Fixed numerous wiring gremlins, replaced some bulbs and a ton of connection corrosion and...
[IMG][/IMG]
Old 09-18-2010, 05:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Cool dash/speedo. Lotsa chrome!
Now, for your next photo I'd like to see the needle registering a nice even 60 mph or so...
Old 09-18-2010, 05:50 AM
Will I ever get it done?
Last journal entry: Driver's Door
Start a journal!
Old 09-18-2010, 07:00 AM
GMCTRUCKS's Avatar
Caddy
Keep on posting the pictures I love the car.
Old 09-22-2010, 03:16 PM
nice pics!
Old 02-02-2011, 09:44 PM
K and K's Avatar
Some updates. Car is much more streetable now...
Old 02-02-2011, 09:56 PM
mud.man.rj's Avatar
caddy
Nice car, does it have the type of headlights that are dark sensing. Can't remember what they are called. I worked on a 56 in town with that setup, it's not as solid as yours, it also had some weird auto trans in it.
Old 02-02-2011, 10:16 PM
Wiki Edits: 31
That's the Autronic Eye. dims from high beam to low for oncomming traffic. common in the higher end cars, tho it was available across GM's car lineup in '57
http://graylady.webng.com/AE%20History.htm
the 57 gasser front end pics fast68 Hotrodders' Lounge 3 08-30-2009 07:44 AM
I need a battery. How much CCA for a Cadillac pre 1962 390 engine garagedoreen Engine 1 01-17-2009 10:49 PM
3x2 cadillac E.F.I. rachet ralph Engine 11 09-20-2008 09:54 AM
available engines in 57 GMC Beastmotorcycle Introduce Yourself 1 01-05-2005 10:29 PM
57 Chevy vs. 57 Pontiac fuel sending unit yenkonova General Rodding Tech 1 07-17-2004 09:59 AM
