57 chev 3100 camber issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2010, 06:44 PM
What causes excessive camber with the original straight axel? I just noticed this on my truck I recently purchased. The kingpins are good, has disc brake conversion. I know the leaf springs need new pins and bushings. Is that my cure? I'm adding PS to it now, and will also need some alignment specs.
Old 11-09-2010, 06:52 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You have to bend a straight to get the excessive camber out to correct it. But you need to know what you are doing cause it can and is a very dangerous process IMHO. Or well that's how we use to do it anyway.
Cole
Old 11-09-2010, 07:05 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
The axle needs to be bent to adjust camber. Shoot for 1/2 degree negative. Any serious alignment shop or one that does big trucks should be able to fix you up.
Andy
Old 11-09-2010, 07:29 PM
alignment specs
Hi vetteman
the toe in is .13 - .22 and caster is 1.5 pos. the factory service manual does not give a camber adj. Im kinda having fr. end probs with my own right now , hope this helps
57 Chev Rear end kruzr Transmission - Rearend 2 03-02-2003 06:57 AM
57 chev truck susp. upgrade/ ?volare or nova clip? murrsue Suspension - Brakes - Steering 7 01-27-2003 10:42 PM
Volare front clip for 57 chev pick-up? murrsue Suspension - Brakes - Steering 2 12-31-2002 02:25 PM
57 Chev disc/power brakes Ice0 Suspension - Brakes - Steering 2 10-17-2002 06:33 PM
Changing to an auto from manual in 57 Chev pikalpha Transmission - Rearend 3 12-14-2001 05:30 AM
