57 chev cast iron power glide need info - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2007, 05:19 PM
I am rebuilding a cast iron power glide and the rear pump drive pin was sheared off and when i put the new pin in it seems like there is a lot of play in the hole the drive pin fits into .
My queustion is is there any way to repair it and make it stronger?
Any info would be greatly appreicated.
thanks
Old 05-30-2007, 01:56 PM
This is the only guy that I know that deals with these old transmissions. It is Ron at Trans-Matic Parts 818 2467788. He is a friendly old guy that knows this old stuff, and should be able to help you.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
57 chev pickup big b Introduce Yourself 1 05-08-2007 07:25 AM
Chev truck power window issue ghomer Electrical 6 01-05-2007 04:50 AM
57 chev frame swap swvalcon Suspension - Brakes - Steering 1 01-29-2006 07:09 PM
Volare front clip for 57 chev pick-up? murrsue Suspension - Brakes - Steering 2 12-31-2002 02:25 PM
