57 Chev truck - 400 Pontiac motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2006, 04:23 PM
jvo jvo is offline
I'm posting this for a co-worker. He recently bought a '57 Chev pickup that someone swapped a 400 pontiac motor into, but, believe it or not, never used rubber motor mounts. In order for the safety inspection to pass here in Alberta, they want him to cut the steel mounts off, and re-mount the engine. Anyone got any idea on a setup that's made for this application, OR, one that can be easily adapted?
Also, he wants to do a disc brake conversion. I did a bunch of searches on motor mounts, and am about to start searching on disc brakes. Thanks. John V.O.
Old 11-03-2006, 05:41 PM
Mount a set of stock later side mounts on the block. Trim the steel mounts so you can weld a tube on for the stock mounts to bolt in and you're done.
Disc conversions and so on are available H&H Classic Chevy in Bentonville AR.
Herman and Trey are great folks to deal with.
Old 11-03-2006, 07:26 PM
jvo jvo is offline
Thanks, we'll try that. I'll do a search on H&H. John V.O.
Old 11-03-2006, 07:30 PM
GMC trucks of that year came with Pontiac engines.
His may be a GMC with a Chevrolet nose sheet metal .
Old 11-04-2006, 10:32 AM
DOUBLEDICK's Avatar
check out he thread "55 to 59 Chevy truck owners" the project journals are full of information.
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
Pontiac 400 vs. Pontiac 455 chevyelc81 Engine 7 03-19-2011 07:31 PM
Help on a Pontiac 400 dirt track motor ridlenracing Engine 9 06-16-2007 10:26 PM
My 81 chev truck project. jayjosey Introduce Yourself 1 10-25-2006 06:07 PM
will a 1969 455ci olds engine bolt right in place of a pontiac 400??? chevyelc81 Engine 3 06-12-2002 03:54 AM
