57 chevy 283 timing issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2013, 09:51 PM
I have a 57 chevy with a 283 and automatic transmission. The engine was running fine but the distributor hold down bolt came loose and the distributor spun. I moved the distributor to where I thought it should be but the engine will not start. What can I do to get the engine started so that I can further adjust the timing.
Thanks.
Old 07-23-2013, 10:19 PM
vinniekq2's Avatar
trial and error until it starts or use the timing light with the engine shut off.bring 1 to tdc for the power stroke,both 0s lined up and turn distributor base(ignition on) and when the light flickers you are close
The Following User Says Thank You to vinniekq2 For This Useful Post:
nsmasullo (07-23-2013)
Old 07-25-2013, 02:24 PM
10 advance at 1000rpm, once you get her running.
peace
Hog
The Following User Says Thank You to Hogg For This Useful Post:
nsmasullo (08-19-2013)
1961 chevy 283 timing marks Duane Heichelbech Hotrodding Basics 1 11-07-2011 02:38 PM
88 chevy 1 ton 350 timing issue BigDtexas Engine 4 04-04-2011 02:16 PM
1989 chevy blazer timing issue blackxlava Engine 1 03-14-2010 01:59 AM
283 chevy timing 56xpresso Engine 11 05-24-2004 07:38 PM
base timing on a 66 chevy 283 powerglide_66 Engine 1 12-19-2003 04:14 PM
