57 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2006, 08:53 PM
57 Chevy
Hey Anyone, How Do I Switch From A 3 Wire To A 1 Wire Altenator For A 283.
Old 09-25-2006, 09:02 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Very Simple..
Just mount the new alternator, and run a 10 gauge wire to a PROPER Fuse link at the power terminal for the car Or the big terminal on the starter solenoid..
The old wires will get capped and insulated and tied back...not used..
Be advised..to excite the one wire alternator, you need to rev it a bit from idle to turn the regulator on..and your idiot lamp will no longer operate.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 09-25-2006, 09:09 PM
57 Chvey
It Is In A 57 Chevy I Think It Has A Regulator Hooked Up, Is This Just Bypassed Then? I Am Not Sure What Size Altenator Is In There Now But The New One Is A 100 Amp, This Wont Be To Big Will It?
Old 09-25-2006, 09:19 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
The regulator may be removed..Any of the larger RED wires that attach on the left side IIRC, should remain connected to each other..(should / Could be the horn relay and the main power buss support wires) but the others will not be used..It may be removed with the stock alternator..
There is no such thing as "Too Big" electrically..because the alternator says 100 amps, that is ONLY it's possible potental...The regulator (internal) will only run until the demand is met, than shut down..I.E. if a 30 amp load is imposed, it will put out only until that demand is met..then shut down..
The only other possible area of concern is upgrade the wire and add a fuse link..10 gauge wire and a 90 amp fuse link should do fine..
Originally, the car did not have a link..(the factory did not install them until about 1970) so you will be adding new..
Doc
Innovations
Old 09-25-2006, 09:29 PM
57 Chevy
Thanks I Will Let You Know If I Start Anything On Fire! Lol Thanks
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
57 chevy pickup DSW Introduce Yourself 6 12-21-2007 10:47 AM
Engine build ideas Rug Engine 23 12-25-2006 02:39 PM
quick question,,,is a 55 chevy and 57 chevy trunk lid the same?? tiresmoke55 Body - Exterior 1 07-09-2006 10:40 PM
57 chevy owner hollywood3319 Introduce Yourself 2 09-05-2005 04:01 PM
