57 Chevy gear ratio? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2006, 08:40 AM
Last journal entry: 40 Chevy coupe
Drive shaft turns 1 and 3/4 turns per 1 turn of the wheel. Can anyone tell my what ratio this might be? Thanks.
Old 10-10-2006, 09:03 AM
About 3.50:1
Old 10-10-2006, 10:45 AM
Thanks for the info.
Old 10-28-2006, 08:14 PM
Can you tell me how to check the rear end ratio as per turns of wheel to driveshaft revolutions? Thanks.
Old 10-28-2006, 08:17 PM
poncho62's Avatar
Wiki Edits: 5
It's a 3.55
To check ratio of a non posi, jack up 1 wheel. Turn it one revolution and count how many times the driveshaft turns. Double that and you have your ratio.
Ontario Rodders
Old 10-29-2006, 05:27 PM
Thanks Poncho. I knew it was something like that. Just did'nt remember to double the driveshaft revolutions.
Old 10-29-2006, 09:10 PM
I turn the wheel twice so I can skip the math.
89 chevy 1/2 ton 5-speed truck gear oil??? tiresmoke55 Transmission - Rearend 12 09-12-2006 10:46 PM
quick question,,,is a 55 chevy and 57 chevy trunk lid the same?? tiresmoke55 Body - Exterior 1 07-09-2006 09:40 PM
Want to change rearend gears in 57 Chevy... HELP!!! Drew's 57 Transmission - Rearend 7 02-21-2006 11:05 PM
Gear Ratio? Mike_82 Transmission - Rearend 2 06-19-2004 12:10 AM
RPM, GEAR RATIO , TIRE SIZES, EQUATIONS zonk Transmission - Rearend 1 01-08-2003 10:16 AM
