57 chevy pick up - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2013, 10:50 AM
57 chevy pick up
Hi guys looking for a opinion time again. I the process of looking for something else I came across a 57 chevy short bed big back glass truck. This truck is in great shape very little rust and the truck is almost all there. But it has a problem. Sometime in the past, before the current owner got it. The engine was swapped for a 389 Pontiac. And that is where the problem lies. What to do with it. It has the badging on the front for a V8 so I am assuming that it was born with a 265 small block. This truck is so complete and in such good shape it's begging for a full resto. But the chances of finding a rebuildable 265 small block let alone a saginaw 3 spd. to restore it is almost impossible.
So do I do a restomod with a built Pontiac. Or maybe a LS6. Or do I do a complete restoration and look and hunt for a build able 265 if that was what was in there. I will have the VIN. sometime today and then I should be able to tell what was in there when new. If it had been born with a I6 then that would be a no brainer, as I've seen lot's of them around.
And yes I bought it, I just look this stupid that don't mean I am. And this is the part that will hurt for some of ya. I am bartering for the truck! Being as how I am a heavy equipment mechanic and the owner of the truck has a construction company. I am going to do some work on his equipment with him buying the parts in exchange for the truck.
I do want to hear your comments pro or con as to what I should do with this truck. I will try to post some picts in a day or so. So tell me what ya think. Bill
Old 05-08-2013, 11:23 AM
Sell the pontiac engine. Put a Chevy engine in it. If you really need a 265 and are willing to pay for shipping (freight), try looking in craigslist in the Los Angeles area. I just did a search and found a long block for 500. Since the engine is not original, just drop what is available and have fun.
The Following User Says Thank You to joeysworld For This Useful Post:
Ironpony (05-08-2013)
Old 05-08-2013, 02:13 PM
Banned
didn't the gmc truck come with poncho power??
you sure it's a chevy and not a gmc with a chevy nose.
The Following User Says Thank You to gearheadslife For This Useful Post:
Old 05-08-2013, 02:37 PM
techinspector1's Avatar
Wiki Edits: 326
I'm thinkin' the same thing and further, I'm thinkin' that the motor is a 347 that would have been used in a '57 truck, not a 389. All Pontiacs used the same external size block, so unless you have pulled the motor apart and measured it, I'd bet you're lookin' at a "stock for 1957 347" that was installed at the factory.
The Following User Says Thank You to techinspector1 For This Useful Post:
Old 05-08-2013, 04:08 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would go Resto=mod on tht truck myself but that is just my opinion..See what you have to work with once it is home..
Sam
The Following User Says Thank You to OneMoreTime For This Useful Post:
Old 05-08-2013, 04:20 PM
I'm sorry it is a GMC Does that mean it may have come with a pontiac when new. That's news to me.
Old 05-08-2013, 04:22 PM
it's a GMC with a chevy emblem on the hood. that's what through me off
Old 05-08-2013, 05:07 PM
Wiki Edits: 31
Yes, GMC used Pontiac V8's as they did not have their own like Chevy, so it is most likely original
The Following User Says Thank You to matt167 For This Useful Post:
Old 05-08-2013, 07:02 PM
50's GMC
Ok guys here is some pict's of the truck. The owner told me it was a 57 but I don't think so. As it has quad vertical headlights. And I can't find anything about a GMC in those years with vertical headlights. So I ask if any of you can help me id this truck. And it does have a Pontiac engine that looks like it was OEM. The owner is looking for the title and says it says 57 on it. So i will post some picts to see if that helps. Thanks Bill
ID:	73861   Click image for larger version
ID:	73862   Click image for larger version
Old 05-08-2013, 07:07 PM
poncho62's Avatar
Wiki Edits: 5
Somebody has stuck those headlights in there...it came with larger single lights.
The Following User Says Thank You to poncho62 For This Useful Post:
Old 05-08-2013, 07:35 PM
Ok guys since I want to build this to sell, so I can get some money to build My 33. I am not talking about a 100 point restoration here. My plan would be to do a frame off resto with a aim at trying to make it as close to stock as I can. Including rebuilding the Pontiac thats in there if it's numbers matching. Would that get me the most return for my money or would doing a really good restomod be the way to go. Let Me know what ya think. Thanks Bill
Old 05-08-2013, 08:26 PM
57 gmc
I have a 57 gmc cab and hood mounted on a 59 chevy short fleetside bed. The front grill on your truck should have the mustache chrome apron and bullets on the front bumper. If I had the brain muscles I would show you a picture of mine. Good luck on the project!!
Old 05-08-2013, 09:34 PM
Wiki Edits: 326
When I look at those headlights, a Chrysler product comes to mind. Maybe, maybe not.
Old 05-09-2013, 07:17 AM
TucsonJay's Avatar
I would be really hesitant to assume there is any profit involved here. I've been around the "car game" for almost 50 years, and the cost of rebuilding a vehicle today is usually as much, or more, than it's worth.
Old 05-09-2013, 07:26 AM
Banned
57 fury maybe
Greetings -48 chevy pick up DayaPillay Introduce Yourself 2 11-30-2012 03:13 PM
65 chevy pick up ms 65 chevy Electrical 1 03-05-2011 05:31 AM
64 chevy pick up chris vail Engine 3 04-16-2010 09:20 AM
help with a 99 chevy s-10 pick up wrestlingclub142 Transmission - Rearend 8 07-05-2006 08:50 PM
79 chevy pick^ 79chevypick^ Body - Exterior 3 08-30-2003 06:56 AM
