57 Chevy pickup rear suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2007, 05:21 PM
57halfton's Avatar
I have a 57 Chevy pickup that I did the Mustang II front susp. and mono leaf rear springs with QA1 shocks years ago. I have never been really happy with the ride out back.
What I am wondering is has anyone in this forum had any experience with aftermarket or custom rear suspension on 55 to 59 Chevy pickups ?
What did ya do ? How did you like it ?
Any input please, Gene
Old 01-14-2007, 06:53 PM
I have used a 4 link riding on coils ... before ... the above is a example ... but not a 55 -57 Chevy ...
On my 55 Cameo ... I used a 68 Chevelle 12 bolt ... made a custom crossmember with coil cans ... and made up a 4 bar ... rode great
I have never done the custom suspension you are referring to, 4 link, etc, however I have done a custom leaf spring suspension. I would reccomend using multi leaf springs instead of the mono leaf. With multi springs you can add and remove leaves to tailor the height and spring rate to your liking. Mine works great and is real comfy. Mono springs are typically pretty stiff.
Old 01-15-2007, 08:39 AM
DOUBLEDICK's Avatar
Go to the hotrodders lounge and check out the thread"55 to 59 chevy trucks".Then check out Kim57's journal he put a 4 link under his 57.Ther are alot of us with these trucks.
Old 01-15-2007, 12:56 PM
tmeyer's Avatar
Check Out My TCI Rear Leaf Setup
I have not drove it by it went in really easy. Form the way it feels pushing down on it, it feels pretty good and may be a little firm which is what I want.
check it out at www.meyerbrosrods.com under Tom's 57Truck
Old 01-15-2007, 03:49 PM
57halfton's Avatar
Thanks guys , great input.
Gene
Old 01-15-2007, 04:06 PM
57halfton's Avatar
Hey DD
That thread in Hotrodders Lounge is huge , i'm going to bookmark it so I can read it all when I get time.
Thanks , Gene
Old 01-15-2007, 11:01 PM
I had a great riding 57 Chev PU. Used a transverse leaf spring and a triangulated 4 bar with plain o gas shocks. Bill
Old 01-15-2007, 11:15 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
Gene
Gene,
Before you go to extremes bolt on a set of Bilstine shocks. You will notice a much better ride.
Old 01-15-2007, 11:29 PM
DOUBLEDICK's Avatar
I use coil over edelbrock sensetrack shocks and a set of traction bars on the back of my 58 and run an extra overload leaf in the spring stack.I also run a rear antisway bar.
Name:	100_1395 (600 x 450).jpg
Old 01-16-2007, 05:27 AM
tmeyer's Avatar
Rear Sway Bar
Doubledick, Has the rear sway bar helped? I am considering one for my '57. I my suspension reading, it has indicated a rear sway bar can cause understear. Would you recommend one for me since I have a large z/28 sway bar in the front with my Camaro subframe.
Old 01-16-2007, 08:55 AM
DOUBLEDICK's Avatar
I would recommend a rear sway bar for every vehicle you own.I just bought one for my 97 astro van.The rear sway bar made a huge difference in the handling and I have the large swaybar on the front.It was most noticeable when passing at speed on the highway.No more rocking side to side.The wind and my trailer stopped pushing me around as well.I noticed no under steer after installing the bar.I drove it for over a year without one.The traction bars affected the steering till I got them dial in though.
Old 01-16-2007, 04:27 PM
tmeyer's Avatar
Thanks Doubledick
Doubledick, Thanks for the recommendation. I am in the market for a rear sway bar.
Tom
Old 01-16-2007, 06:11 PM
57halfton's Avatar
Originally Posted by solidaxel
Gene,
I thought the QA1 shocks would work , they did work pretty good, but the big problem is the mono leaf controling the rebound. I have thought about Bilstine shocks, but I think I gotta get rid of the mono leafs.
Gene
Old 01-16-2007, 06:29 PM
57halfton's Avatar
I like the idea of the triangulated four bar, but I used a 67 Chevelle 10 bolt rearend and cut off the mounting ears on the center casting where the upper trailing arms went.
I'm thinking about the FAT BAR 4 link setup from NoLimit Engineering with air bags , Any thoughts ?????
57 chevy pickup DSW Introduce Yourself 6 12-21-2007 09:47 AM
53 chevy pickup rear window Beaver Dam Body - Exterior 4 10-29-2005 08:14 PM
57 Chevy Rear? Sanspants Transmission - Rearend 12 03-14-2005 11:55 AM
1947 Chevy Aerosedan 4-Link Rear Suspension Kit??? djjc76 Suspension - Brakes - Steering 3 09-10-2004 03:06 PM
Brake / Suspension Upgrade - 75 Chevy Pickup dwstevenson Suspension - Brakes - Steering 0 12-31-2002 07:42 AM
