57 Chevy pulls to left when braking - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2004, 04:25 PM
1957 Cheby belaie pulls to the left when I apply the brakes.
replace brake hoses, spring set, all suspension rubber.
any ideads how to fix?
Old 10-13-2004, 04:57 PM
arch's Avatar
My bike has 4wheel disc brakes
Check:
Tire Pressure, Front end alignment, Matching tires, Hoses clear, Calipers (malfunction), Rear brakes, Tighten suspension, tighten calipers.
Old 10-13-2004, 04:59 PM
poncho62's Avatar
Wiki Edits: 5
If original, change your wheel cylinders. Make sure that the shoes are adjusted evenly.
Old 10-13-2004, 05:13 PM
brakes pull to the left
I've replace brake cilinders, spring set,rebuilt suspension,
wheels are 14's checked air, adjusted various time.
I've also replace brake hoses, these are all drum brakes,
I have not changed drums, can these cause the pulling to
the left?
Old 10-13-2004, 10:03 PM
If the car is pulling to the left you can bet something on the right is not working correctly. There is a chance that the new wheel cylinder is not working correctly but I would check the adjustment on the two front wheels first. There is a chance the brake shoes on the left are contacting the drum before the right shoe reaches the drum, thus pulling the car to the left.
Try this simple procedure. Jack up the front of the car so that the tires are off the ground. Have someone apply the brakes to about 60% of the maximum so you can still turn the front wheels, while the brakes are applied. Each front wheel should require about the same pressure from your hands to turn the wheel. If they don't, adjust the brakes on each wheel until both wheels require about the same strength to turn, thus assuring that the shoes are contacting the drums at the same time. I do the same thing for the back on my car so that all four drums have the shoes contacting at the same time. I have used this procedure for years and it works great.
Old 10-14-2004, 04:22 AM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
If your right front brake hose goes through small tube support be sure its not squeezed to tight on hose,had that problem on my daily driver.
Old 10-14-2004, 09:29 AM
Slickriffs's Avatar
Belair..
About 2 years ago had the same problem with my 55 truck. By process of elimination replaced cylinders, shoes, hardware etc..still pulled to the right and often would lock up and skid.
It finally occurred to me that there was "another" brake adjustment.
Where the brke shoes sit at the top...there's an eliptical shaped bolt with a lock nut..By adjusting this you change the geometry of how the shoes relate to the drums. Worked like a charm for me. Dialed the problem right out. Not sure why all of a sudden this needed tweaking, but it did.
Possibly you have this adjustment on your ride? If not disregard all the above chatter
Keith
Old 10-14-2004, 11:57 AM
Also check the rear brake adjustment. If one side is out of adjustment at the rear it will also cause a brake pull.
