57 chevy rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2002, 02:00 PM
New Member
Post 57 chevy rearend
can anybody tell me if you must pull the axels to take out the third member on a 57 chevy rear end. i just want to check to see what gears are inside
Old 10-15-2002, 02:54 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Yes, you must pull the axles to get the pumpkin out. Why do you want to do that? Just jack up the rear end on jack stands. Then rotate the driveshaft until the rear wheels rotate 10 times and count the revs of the driveshaft(both wheels should rotate forward for this to work but they usually do). Then divide the driveshaft rotation # by 10 and you will know the ratio. For example, assume the wheels go around exactly 10 times and the driveshaft goes around 35 1/2 times. The gear ratio is this 35.5/10 = 3.55:1.
Old 10-17-2002, 04:19 PM
New Member
Post
I know the 55 chev has a 4.56 ratio.
Old chevs were made with very thin metal, but were very common in drag racing
1952 Ford F1
1930 Model A 302
1928 Graham Paige Victoria
Old 10-17-2002, 05:29 PM
New Member
Post
**** can the whole rear end and get a disc brake ford nine in.
Old 10-21-2002, 10:36 AM
New Member
Post
THANKS FOR THE HELP I'LL TRY THAT
TALK LATER
Old 10-23-2002, 09:07 AM
Post
I'm putting a 68-74 Nova rear in my son's 57 Belair 2dr Sedan. Everyone I've talked to said it's a one-day swap, same u-joints, same driveshaft length. Hope so, but I'm rebuilding the brakes and installing new steel lines and flexhose before I tear the car down.
