'57 Chevy Short Bed PU - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2013, 09:26 AM
Anyone put a small block x-member (Classic Industries) in a 57 PU? Didn't like the front motor mounts so opted for this adapter. Any insights would be appreciated.
Old 04-08-2013, 10:08 AM
ogre's Avatar
the 'Duracell Project'
what trans are you using? stock with side mounts on the bell housing or a newer trans with the rear trans mount?
Old 04-08-2013, 11:58 AM
Rear Mount
I'm using the powerglide out of my 64 Chevelle with the rear mount, which is the main reason I went with the crossmember motor mount setup instead of the front mount conversion, actually the stock 57 V8 mounts.
Old 04-09-2013, 12:26 PM
ogre's Avatar
yes you need side mounts on the motor when you get rid of the bellhousing mounts.
motor mounts are the easiest project to fab up at minimal cost
the x-member your looking at will need trimming and welding to fit
you can fab up your own in the time it will take you to order those
my 58 has a mustII x-member, i fabbed these motor mounts out of 1.5 square tubing and used 68 truck mounts
these are on a subframed truck but if you have a stock frame just run another gusset to the bottom frame rail
my truck used a similar mount when it was a little more stock
Old 04-09-2013, 03:23 PM
Thanks
Very nice fab on yours. I kept the 6 bolt lug pattern. It probably will cost me more in the end by the time I hang a booster, disc brake kit. I found a pretty reasonable kit / cross member and I'll take your advice and fab the tranny one. Thanks!
Old 04-09-2013, 04:56 PM
RWENUTS's Avatar
If you're hanging a booster on the firewall you'll need some extra bracing on the backside under the dash. The stock firewall is not very strong.
crossmember v8
77 chevy short bed 77chevy254 Introduce Yourself 2 12-13-2008 05:14 AM
dropping a 79 chevy short bed hemigremmy Suspension - Brakes - Steering 9 03-13-2007 11:05 AM
1985 Chevy Short Bed Truck 1931 steve Hotrodders' Lounge 5 09-13-2005 09:57 PM
'86 chevy short bed smuhammad Suspension - Brakes - Steering 0 01-07-2003 12:50 PM
'86 Chevy C-10 (short-bed) P/U smuhammad Interior 0 01-07-2003 12:35 PM
