Hi,
I don't think I would use what you have there, I'd either buy an engine swap front mount, or engine swap side mounts for the 57, also what do you plan for a trans? Rich |
Well then you'll want to use side mounts, front mounts make it
hard to use a different trans, here is a link for mount conversion http://www.speedwaymotors.com/p/1177...ount-Kits.html PS you'll also need a larger radiator (more cores) as the six cyl one wont do. Last edited by richard stewart 3rd; 10-10-2008 at 11:11 PM. |
Right, I was planning to use side mounts. What I wanted to know was whether or not the side mounts that are already there will work with a small block. Since the 6 was a later model and used side mounts, the same as if you had a 6 in a Chevelle or Camaro etc., can you use the 6 cylinder mounts to install the small block if you have the right rubber motor mounts? Or, do you have to replace the chassis mounts in cars like that to replace a 6 with a small block?
Because if I could keep the same chassis mounts in those cars with a 6 and just get the right rubber mounts for the block, then I should be able to do the same thing in my '57. |
Looks like I found my answer.
This is from this site: http://rmcavoy.freeshell.org/6to8.html Quote:
| big block or small block chevy | 69YENKONOVA | Engine | 81 | 05-13-2010 07:26 AM |
| My 350 Small Block Chevy. What do I have? | Frank the Tank | Engine | 29 | 09-08-2007 06:33 PM |
| Chevy Small Block Heads | druss32 | Engine | 17 | 05-10-2006 08:35 PM |
| Chevy 400 Small Block to 350? | jdt40u | Engine | 4 | 07-20-2005 11:19 AM |
| anyone supercharging a small block chevy? | csangster | Engine | 6 | 11-14-2004 12:47 PM |
