57 Chevy Spring problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2007, 06:38 PM
Just installing new 3" lowering Super Slide rear springs on my 57 Nomad and I am having a heck of time getting the shackle thru both the spring eye and the hanger eye. I rotated the spring eye above the hanger and frame like I did to remove the old springs but the new spring is so close to the hanger that there is not enough room between them to slide the shackle thru both eyes at the same time. I tried a crowbar, moved axle up and down, still not enough space. Anyone else had this problem? Any and all help appreciated.
Dave B.
Solved problem by swapping shackles side to side and entering the spring and hanger eyes from between the frame rails rather than outside. Not according to original design but the same results.
Old 11-28-2007, 07:59 PM
31 five window
Last journal entry: Moving along with patch panels.
Try getting shakles in before front spring bolts.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
57 chevy owner hollywood3319 Introduce Yourself 2 09-05-2005 03:01 PM
57 chevy wiper conversion romine Electrical 2 12-11-2004 01:06 PM
Anyone using the Maval/Unisteer rack&pinion in a '57 Chevy fordSR Suspension - Brakes - Steering 2 12-09-2004 01:56 PM
57 Chevy Generator to Alternator dirtroaddrifter Electrical 1 12-06-2002 08:08 PM
