#1
57 chevy truck front clip removal
can the entire front clip be removed from the truck as a unit, fenders rad support grill ect?
Register now (free) or login to remove ads |
#2
You should be able to take it off as one..
#4
Take the hood off , it bolts to the firewall then there is 1 bolt at the bottom of each fender, another at the top near the cowl on each side. Then the 2 on the core support , each side of the radiator. There is also 1 on each side at the bottom of the inner fender where it comes to a point near the bottom of the firewall. You may have to remove the bumper to get the frontend off. If the frontend has never been off the bolts could be rusted and not come out very easy , be careful of the bolts at the bottom of the fenders , thats where the fenders rust badly. And be very careful with the old brittle wiring.
Gene |
| Thread Tools | Search this Thread |
| Similar Threads for: "57 chevy truck front clip removal" | ||||
| s-10 front clip on a 50's chevy truck | smokinbrinkman | Suspension - Brakes - Steering | 6 | 07-08-2008 11:48 AM |
| Clip the front of a 59 Chevy pu with a 70 Camaro Front clip? Will it work? | classicappraiser | General Rodding Tech | 6 | 10-16-2006 12:05 PM |
| Front clip / subframe for '52 Chevy Truck | dcostellow | Suspension - Brakes - Steering | 8 | 07-25-2006 02:39 AM |
| Best front clip for a 1950 chevy truck | LNOVA | Suspension - Brakes - Steering | 7 | 01-29-2006 09:52 AM |
| front clip replacement on 1953 Chevy Truck | chevyheaven1 | Suspension - Brakes - Steering | 3 | 11-08-2004 09:17 AM |
