57 chevy wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2013, 12:12 PM
57 chevy wiring
Can someone tell me if the 12 volt or 6 volt side of resistor goes to distributor?
Old 04-24-2013, 04:43 PM
EOD Guy's Avatar
The resistor takes 12 volts and reduces it to 9-ish volts so as not to burn up the coil and the points contacts
Old 04-24-2013, 07:37 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The resistor is wired in series with the ignition wire to the coil +. The resistor will not have an IN or OUT connection point. It's the same resistance no matter which way it's connected.
vicrod
70 chevy c10 wiring(help) 2burnouts Electrical 4 11-10-2010 05:35 PM
chevy a/c heating wiring mmcs Electrical 1 10-19-2008 05:45 PM
Wiring for '48 Chevy FrankieG Hotrodding Basics 6 12-23-2005 06:29 AM
Wiring Question 65 Chevy EazyDuzIt102 Electrical 1 03-14-2005 01:39 PM
57-65 chevy wiring diagrams akm Hotrodders' Lounge 1 11-16-2004 05:08 AM
