Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 57 ford /gm 605 p/s wanders bad
Old 08-29-2006, 03:48 PM
aka Duke of URL
Originally Posted by 60tbirdrick
At first they said that the fluid temperature is getting too hot and causing the tollerances to close up and to add a cooler to the system. I did this and the problem did not go away so i added another cooler and the problem is still there but not as bad.
This is basically fixing the symptom and not fixing the problem. Gearheads seems reluctant to respond to these issues for some reason. I am hoping to get this resolved soon as my summer cruzin plans went out the window in a hurry.
Awfully expensive add-on not to work properly or bring much interest from the vendor.
Please keep us informed if you can. Usually, hot fluid just leads to seal deterioation. If the thing is locking up, I would think there is something wrong in the way they adapted the housing leading to some type of binding inside.
Have you come across other complaints?
