57 ford /gm 605 p/s wanders bad - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 12-06-2006, 05:20 AM
aka Duke of URL
So It Continues...
-ANOTHER REFERRING URL-
  #47 (permalink)
Old 01-06-2007, 11:21 AM
grandpaws 57's Avatar
"Don't need no V/8"-grandpaw
gearheads update
filed a complaint with BBB of MN/ND.Asked for buyback of $800.00 out of $1196.00.I feel this was fair.My feeling is that the part[sector shaft teeth] were defective and they knew what they were selling.Or mabey they are blind !!Gearheads cruzier products offered to repair box,but,why did they sell it in that way in the first place????
  #48 (permalink)
Old 01-06-2007, 11:28 AM
The Maintenance Geek
There is only one guy I'd trust with repairing that box,
redhead steering, in Seattle...
K (just a satisfied customer)
  #49 (permalink)
Old 01-06-2007, 01:12 PM
gm605
thanks for the tip.
  #50 (permalink)
Old 01-06-2007, 01:36 PM
aka Duke of URL
At least you got their attention! Good Going!
  #51 (permalink)
Old 01-06-2007, 02:44 PM
thanks for kind words
This whole affair would have not happened if they had pride in their workmanship! The part that bugs me the most ,I LOST A SUMMER OF CRUISING IN MY CAR!!!!!! Thanks Gearheads cruzier products
  #52 (permalink)
Old 01-07-2007, 06:26 AM
60tbirdrick's Avatar
Sacred Steel
Last journal entry: The dash
I am in the same boat, and I am sure there are many more of Gearheads customers that are unhappy. After many weeks of emails and phone calls to them, they finally offered to look at my box. I took them up on that because I have no other alternative since I donít have any of the original steering parts although I do have another steering box that I think may work. I will make a separate post on that. I would like to tear the 605 down to look at the internals like grandpaws 57 did but I canít be without a steering system. They sent the box back and I installed it and I drove it around a little but not enough to see if the binding problem was fixed. Iíll have to wait for the summer for that when the weather gets warm. I emailed them to ask what was wrong with it and all they said is that they replaced several components. I really donít have a good feeling about it though.
  #53 (permalink)
Old 01-07-2007, 07:27 AM
BarryK's Avatar
Could very well be in your gear box but if all the other suspension parts are new, there is one other thing you need to check that will cause this problem.
First check is check distance from top of both front tires to edge of fenders.
The real check will be Doing an X measurement on your frame to see if square.
It is not uncommon for these cars to have been hit in front (left in your case)
and not be pulled out properly but the sheet metal made to fit.
If your gear box is good from what you described from the fire wall forward your frame could be 1/2 inch to an inch to the left or left rail could be 1/2 to and inch forward from the right.
This may or may not apply to you but have seen this way to many times with the 55-65 fords and may be worth a check.
  #54 (permalink)
Old 01-07-2007, 08:26 AM
frame damage
I don't know about others,but,I know the history of my car.Even with old manuel box car drove better than Gearheads system.Every tech that has seen sector shaft has been shocked ,looks like a jrhigh shop product.
  #55 (permalink)
Old 01-07-2007, 09:45 AM
BarryK's Avatar
Well did not mean to insult you but I about fell out of the chair laughing when I read your response.
Last Feb I saw a fully restored 57 factory supercharged for sale for $65,000, awful cheap. The owner and restro shop had been trying to figure out why his car did the same thing as your except to the right.
As soon as I drove it I knew the problem.
The only mistake the shop made was having the gear box rebuilt and putting on radial tires and both items magnified the problem that was not there before.
This guy owned the car since 72.
The car was very sentimental to the guy so i told him what it was and his response was the same as yours, so with that I said fine and bought the car.
Three frame machines and $2200 later and an alignment, I sold the car back to him for $85,000.
Takes ten minutes to measure.
  #56 (permalink)
Old 01-07-2007, 03:08 PM
that my be
I thank you for your concern.Mostly it is in the past.I've got a rack,drives like new car now.I would like part of my money back.I am sure if you saw pictures of part you would still be out of your chair.
  #57 (permalink)
Old 01-07-2007, 05:35 PM
59 wagon man's Avatar
just got home from the ford show in silver springs fla. met a guy with a very nice 59 country squire sedan . he is the original owner and his only issue seems to be with his power steering. you guessed it gearheads 605 box when i described your problems to him he said it was exactly the same with him. he even said he used to post a note with his car to avoids gearheads. Grandpaws topic has definately caused gearheads some business as they continue to call me about when i want to have my box made . i have purchased a wurthit r/p. .So VENDORS beware offer your products but make sure you give cusomer service if you want to succeed and Buyers check with the website to see if anyone has had any dealings with the company
  #58 (permalink)
Old 01-07-2007, 07:07 PM
another customer
thanks for the futher imput.When this all began I wondered why my box was like that.In the last few months it has became clear that this was not out of the norm.
  #59 (permalink)
Old 01-24-2007, 09:52 AM
update 1/24/07
No responce from GEARHEADS CRUSIER PRODUCTS to BBB on my second letter.I wonder if they have checked COMPANY REVIEWS ?!!
  #60 (permalink)
Old 01-24-2007, 10:35 AM
poncho62's Avatar
Wiki Edits: 5
Was wondering how you were making out with them......Not suprised, eh?
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
Ford 9" in a 57 chevy? Rodrunner Transmission - Rearend 4 04-18-2003 06:29 AM
Ford 9" in a 57 chevy? Rodrunner Transmission - Rearend 1 04-16-2003 10:39 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
9" Ford (Bad gear set from Summit?) mcbroom Transmission - Rearend 4 02-07-2002 03:23 PM
