57 Ford master cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2008, 11:23 AM
I am having trouble finding a master cylinder and clutch slave for my 57 Ford F100 L6. Is there an adaptable part that I could use to enhance the brakes and clutch? Or do I need to continue to try to locate these parts? Thanks guys.
Laurie
Old 02-28-2008, 12:01 PM
31 five window
Last journal entry: grill and rear end
If kits are available you could have yours sleeved. You could sleeve them with stainless and be done for a long time.
Old 02-28-2008, 12:10 PM
57 ford
Thank you for the info. I will check it out.
Old 02-29-2008, 04:59 PM
The Maintenance Geek
Go here...
http://www.rockauto.com/catalog/x,ca...,parttype,1836
And for the clutch, go here...
http://www.rockauto.com/catalog/x,ca...,parttype,1996
Easy-peasy...
K
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
Master cylinder recommendations wheel-7 Suspension - Brakes - Steering 3 11-04-2004 02:43 PM
32 ford manual/drum brake cylinder? help! zuppamon Suspension - Brakes - Steering 2 10-27-2004 05:30 PM
Help! Going Nuts! Mysterious Master Cylinder delstretcho Suspension - Brakes - Steering 6 03-11-2003 05:54 AM
