57 Gmc 347 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2010, 09:00 PM
57 Gmc 347
I just picked up a 57 GMC 100 with a 347 with a 2bbl and manual trans. Problem is, all the info I can find on the 347 states that the # on the block should be 523293. Mine is 523283. One # off. Looks like 347. It has the coolant inlets on the heads. Could anyone tell me why mine is one # off? Also I have a 4bbl Edelbrock carb I want to put on it, so I need a 4bbl intake. I know Edelbrock stopped making an intake for the 347. Does anyone know another intake manifold I could use? And do I have to change the cam? Thanks, Scott
Old 07-28-2010, 09:04 PM
bigdog7373's Avatar
Of course it's fast
GM casting numbers are difficult to read. That 8 is probably a 9.
Old 07-28-2010, 09:24 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That is a Pontiac engine.
The serial number of the engine is stamped on the right side on the oil pan rail. The beginning digits is the engine cid.
I would keep the 2-barrel if it were me, but you can certainly get a factory 1964-back (IIRC) 4-barrel intake, or hit up eBay for an old aftermarket intake.
I agree the casting number was just blurred during manufacturing and is likely a "9", not an "8"
Old 07-29-2010, 09:39 AM
Two8tyThree's Avatar
Last journal entry: Picture of delivery
Try this link.
http://enginefacts.com/pontiac347.php
Does the 389 manifold not fit the 347?
1955-60-PONTIAC-OFFENHAUSER-2x4-INTAKE-326-347-389
Old 07-29-2010, 01:33 PM
57 gmc 347
Thanks guys. For now I'll use the 2bbl while I look for a different intake. Also, I have a powerglide and a T400 trans. Anyone know how I can make one of these work with my 347. Do I need an adapter?
Old 07-29-2010, 03:52 PM
Check out this site. These guys should have the answer to your questions.
Pontiac Heaven
Old 07-29-2010, 04:44 PM
Will I ever get it done?
Last journal entry: Hood
Offenhauser dual quad #5162
dual quad high rise #5707
tri-power #5028, 5255, 5255TP
6 - 2's #3946
Old 10-21-2015, 06:09 PM
Tri Power 5255TP
Hello; I am looking for an Offenhauser 5255TP tri-power manifold. I will appreciate any assistance in locating one in good condition. Thank you!
Old 10-21-2015, 06:45 PM
BOBCRMAN@aol.com's Avatar
Powerglide will need adapter, not a direct bolt up. The 400 has to be BOP belhousing but there is a starter problem on early to late Pontiac conversions.
57 GMC Project ShadetreeTim Introduce Yourself 2 02-16-2010 06:58 PM
pontiac engine 57 GMC truck raiderdog Hotrodding Basics 5 12-27-2008 09:48 PM
available engines in 57 GMC Beastmotorcycle Introduce Yourself 1 01-05-2005 10:29 PM
Chevy v.s GMC truck A-arm lengths? Gearhead forever Suspension - Brakes - Steering 6 09-10-2004 11:15 AM
