IF the check ball was in the valve body when you disassembled it, I would put it back in.
Or did this fall out when you disassembled the Vb and now are attempting to reassemble the parts?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Actually I figured out where it goes by taking another close look at the book. However I also figured out that it is supposed to have another check ball, one with a spring. The second check ball with the spring was not anywhere in the plate when I pulled it apart and I didn't drop anything, I was very careful. Allot of the things in the valve body seem to be inconsistent. It has spools and springs from a '57 in some places and from a '58 in others, but the tag on the transmission clearly identifies it as a '57 and it came out of a '57. Was there some sort of hybrid
You are dealing with a 40+ year old tranny.
Vehicle manufacturers often change things as the year progresses. There may have been updates from GM or early shift mods performed by a trany guy during a rebuild for a better operating tranny. Check balls leave witness marks where they ride/sit. Either on the steel separtor plate or the cast iron of the v-body. These marks are shiney spots or smooth cast iron which is never smooth. ![]() A spring loaded check ball may have been a check valve for avoiding drain back in the tranny. Later it may have been found to be un-needed. GM did this in the T-400. they had several check valves in the pump for drain back form the converter. These valves were eliminated in later years. I could also point out a similar deal in the 700/4L60 pump
