57 Olds brake system. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2011, 06:33 PM
Am doing a disc brake conversion on my brothers 1957 Olds 88. The original system has the pushrod from the brake pedal to the booster/master cyl right behind the base of the brake pedal, ie you are gaining no leverage at all from the pedal. I am wondering if it will work if I adapt a 1" bore dual circuit willwood type master cyl onto the back of the original booster? Or is the pedal pressure going to be too hard? I have been told its practically impossible to push the pedal if you just replace the old booster/master cyl with an after market unit. Help please!!
Old 11-12-2011, 08:09 PM
1badLemans's Avatar
I don't see how the pedel effort would be more with an aftermarket master cyl, did the person who said this say why it would be? I was going to suggest a newer style master and dual diaphram booster to go with it to boot. Don't forget your prop valve
Old 11-15-2011, 01:14 PM
The pedal pressure is going to be greater because I am going from drums to discs. I am just wondering whether an aftermarket dual diafram booster would be more effecient than the factory one and maybe regain some of the effort required at the pedal. I have actually already tried to get the new booster in place and its a bit of a squeeze, so might be stuck with the old one yet or have to make a bracket to offset the position of the new one.
Brake system Javelin69 Suspension - Brakes - Steering 3 06-02-2009 04:16 PM
brake system help frank88chevy Suspension - Brakes - Steering 2 05-04-2009 03:03 AM
Brake system 86Ford Suspension - Brakes - Steering 12 01-03-2009 10:25 AM
help with brake system Samsonian Suspension - Brakes - Steering 2 10-24-2007 08:40 AM
Brake System Flush RAW Suspension - Brakes - Steering 5 03-12-2003 08:05 AM
