'57 Olds front suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2013, 04:48 PM
Charlyg's Avatar
Hi All. Am building a '57 olds super 88. Any suggestions as to front suspension improvement? disc Brake Kits? Front clip? Aftermarket susp kits? Don't mind aftermarket stuff if it's heavy duty enough. Using a 455 BB. Also interested in changing to rear discs also but would like to keep stock rear-end. All suggestions greatly appreciated. thanks!
Old 01-18-2013, 09:04 PM
I built a '57 Olds a few years ago. It always seemed like the perfect candidate for a GM sub frame but I never did do it.
John L.
Old 01-19-2013, 06:25 AM
Wiki Edits: 27
Wiki
There is a Wiki article here on hotrodders about upgrading 37 to I think 59 big GM cars, BUT most of the various GM parts listed are very hard to find, There are a few Builds on the HAMB forums about swapping in Jaguar XJS front and rear suspensions to those years of bigger GM cars. Around here I have got Jags for $100 to $ 150 front or rear with brake pedal, M cyl, drive shaft, etc, we pull. Jags have big and heavy 4 wheel Disc's and the rear gears are a british design of the Dana 44
The Following User Says Thank You to timothale For This Useful Post:
Charlyg (01-20-2013)
40 olds c4 suspension rockenrandy Suspension - Brakes - Steering 2 06-19-2012 09:12 PM
corvette suspension into 53 olds should i? orjamie Suspension - Brakes - Steering 4 01-22-2007 01:37 PM
new suspension for a 48 olds, will it work 49olds Suspension - Brakes - Steering 8 01-06-2005 05:26 AM
Front Suspension 53 Ford Front Clip PaulNJ53Ford Suspension - Brakes - Steering 2 08-11-2004 10:12 PM
86 comaro front suspension " in 39 olds coupe" Hal Bemis Suspension - Brakes - Steering 10 01-18-2003 06:48 PM
