57 olds front wheel bearings and races - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2013, 07:43 PM
sdj sdj is offline
Hi, does anyone know where I can get roller bearings and races instead of ball bearings inner and outer for front wheels of 1957 olds? any help is greatly appreciated. Thanks, Steve
Old 07-29-2013, 08:44 PM
BOBCRMAN@aol.com's Avatar
northwesternautosupply.com/
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
sdj (07-30-2013)
Old 07-30-2013, 11:45 AM
I know for the 57 Chevs that the ball bearing setups are almost $275 for the ball bearings/races alone. There is a tapered roller bearing conversion kit that includes the bearings, races and later model hubs for and the roller
New hubs and roller bearing package $399
Chevy Hub Conversion Kit, Tapered Roller Bearing, 1955-1957 - Ecklers Classic Chevy Parts
Reconditioned hubs with new tapered roller bearing package $289
Chevy Tapered Roller Bearing Hub Conversion Kit, 1955-1957 - Ecklers Classic Chevy Parts
Replacement stock ball bearings that complete both sides of the front end $239.00
Chevy Wheel Bearing Kit, Front, 1956-1957 - Ecklers Classic Chevy Parts
Replacement tapered bearing package for the next time after you have already converted to the tapered roller bearings the 1st time. It says this kit uses races $15.99
So $15.99 vs. $239 for the ball bearings that need repacking every 25,000miles.
Chevy Wheel Hub Tapered Bearing, Race, Seal Kit, Front, 1955-1957 - Ecklers Classic Chevy Parts
Here is the same kit but doesn't use bearing races $15.99
Chevy Wheel Hub Tapered Bearing & Seal Kit, Front, 1955-1957 - Ecklers Classic Chevy Parts
This all from Ecklers 1955, 1956, 1957 Classic Chevy Parts - 55, 56, 57 Chevrolet Parts - Ecklers Classic Chevy Parts But I don't know if the Chev stuff will eb the same as your Olds.
I will be doing this replacement or conversion myself.
peace
Hog
The Following User Says Thank You to Hogg For This Useful Post:
sdj (07-30-2013)
what is the correct proceedure for tightening front wheel bearings 37 ford original 37ford4dr Suspension - Brakes - Steering 5 02-17-2011 12:13 PM
Installing wheel bearing races kleen56 Hotrodding Basics 13 05-07-2010 11:23 AM
Wheel bearings atlantis Suspension - Brakes - Steering 8 01-31-2005 06:06 AM
wheel bearings stoney 81ta Suspension - Brakes - Steering 2 03-20-2004 05:56 AM
Front Wheel Bearings black66 Suspension - Brakes - Steering 10 06-02-2003 08:31 PM
