57 pontiac 287 edelbrock 4 brl manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2011, 07:37 PM
i'm considering using the 287 motor for my 57 chieftan. hoping that i can find a 4 barrel intake for it. i'm dropping the idea of putting a small block in it , because i don't think all the changes i need to make are worth the effort. the frame rails are so far apart that it would require many hours of fabrication. i just baught a manual for the transmition, and if it is spent i will buy an adapter plate and put in a turbo 350. so my question is did edelbrock make a manifold for this motor? or do i have to find a cast iron one from a swamp motor?
Old 01-25-2011, 08:19 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Good luck on finding that intake all i can find is 3x2s Or 2x4s.
I would call edelbrock and offenhauser or whoever sells offy intakes.JMO
Cole
Old 01-25-2011, 09:13 PM
327NUT's Avatar
My sincere congrats on not going with a sbc, keep it all Pontiac!
Old 01-25-2011, 09:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The 287 had a 4-barrel option, also any 4-barrel intake can be used through '60, IIRC.
Here's a list of casting numbers to look for:
521208
521512
521571
523814
528578
532120
532120
536518
535482
Good luck, and that you went w/a Pontiac engine.
1955 Pontiac 287 CID V8
Old 01-26-2011, 10:33 AM
machinist & fabricator
i have a hillborn set up for your engine
its going to take me hours of fabrication to adapt it to my RA IV heads!
Old 01-26-2011, 07:47 PM
i did some more investigating, i'm going to be looking for a EP-4B, translated to, early pontiac - 4 barrel, edelbrock. i called edelbrock and they stopped selling that intake in the mid 60. looks like a swap meet item.
Old 01-26-2011, 08:09 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That's a '61-'64 intake. Whether it can be made to work w/the earlier engines, I don't know.
1961-'64 Edelbrock EP4B Pontiac Intake
1960 Tripower Intake, Part #535552
More photos of various early and later Pontiac intakes, HERE.
Old 01-28-2011, 10:04 AM
i was told from an edelbrock rep. who looked it up in the archives that i needed an EP-4B, and that would fit my applicationfrom 1955-1964. He also told me not to use a P-4B, that was for the newer style motors, 1964 and up. Is this info correct? i was also given a part number of 2265, where that would be is beyond me?
Old 01-28-2011, 01:52 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
To be totally candid w/you- I do know know for sure what the differences are between the '55-'60 head water passages and the '61-'64 heads. I do remember there being a difference, though.
The OE intake is not a bad piece, except for the weight. There will not be an appreciable performance gain by using an aftermarket aluminum intake- it will be a visual thing only, IMO.
If you're looking for visual appeal, consider a Tri Power. But for a single 4-barrel aftermarket intake, I cannot help.
Old 01-29-2011, 01:07 AM
JeffB's Avatar
For the Offenhauser manifolds Google Exeter Auto Supply,they handle a lot of old Offy parts the catalog is available online in Pdf there.
Old 01-29-2011, 01:10 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I looked there- I didn't see anything (single 4-bbl.) for the '55. Wouldn't hurt for him to look again, though.
problem with my new edelbrock manifold jak327 Engine 3 03-12-2009 01:34 PM
Edelbrock torker II manifold cameano Engine 1 05-06-2006 04:42 PM
Edelbrock Manifold Question hiimed Engine 12 10-16-2004 10:26 PM
'97 crate 350 - what edelbrock manifold? THC3PO Engine 5 06-28-2004 05:56 PM
Edelbrock TBI Manifold Problem? erichb Engine 4 12-06-2003 10:29 PM
