57' Suburban IFS swap
Any advice on an IFS for a 57' Chevy Suburban? I measured up a mid 70's camaro and it's very close to sub's width. Any opinions are welcomed.
Thats what a lot of guys are using...............also up to 87 "G" body (Monte Carlo etc) front frame sections............
Ontario Rodders |
NEW INTERIORS just did a 58 with a Nova clip. It looks great, check out his photo gallery.
Kim 57,Really nice job, but if you install Camaro or Nova clip properly it lines up to. Just take a look at NEW INTERIORS photo gallery,he just put a Nova in a 58.I think people who put the whole Camaro or Nova frame clip under the truck frame must not trust their welding skills,No insult meant,But we just cut them off in the right place and line them up and weld them like you did.
Kim57 !!I do my camaro and nova's the same way you did your truck.I don't put it under the frame,I blend it in the same way you did.
I used a 1970 chevelle front frame clip on a 1957 chev truck. It fit good , drove good, sat low.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
They are all getting hard to find now.
All of the advice is great. I have found some donors but I'm waiting a little bit until the some more snow melts to find one this isn't completely rusted out. I'm leaning towards the camaro. I want the 57' sitting respectably low. I have not welded on a frame clip before and I'm just trying to do it in a way that's going to be safe and correct. I'm staying away from the MII for financial reasons. I want to learn how to do this. Thanks everybody for the info.
If you know how to weld and you have patience it is not that hard.First step is to measure your wheelbase before you cut your old front section off. This way you have figures to line up your new one.The camaro clip has frame sections that run back under the car. These should be level. Before you cut them off ,level the clip front to back and tack a piece of flat bar in the middle of the cross member level so when you cut your clip you will have a reference point to level your clip to your frame.The farther back you cut the truck frame the farther back you will have to cut the clip .The farther back the lower the truck will sit. You have to decide where to cut for how low you want it to sit.
Thanks speedydeedy, I do know how to weld and will make sure to measure twice and cut once. I have taken some dimensions down already. I just have to make it the bone yard to find the donor. I plan on taking pics to show the progress. Will the stock springs be adequate for a BB chevy?
Yes the springs will work fine.If you look in NEW INTERIORS photo gallery you will see a 57 that I started and he finished. I put a 81 Firebird clip and a tall deck big block 427 with TH400 and had no problems with weak springs.
The car was set up to high in the front,so I cut it,And Z the frame 2-3/4'' to get the right look for the car.And the spring did go down alot,The a-arms where a little under level.this is a before and after.
I checked out New Interiors journal. I will be using it for a good reference. Thanks for the tips. Hopefully coming home with a clip Friday after work. Thanks guys.
| Vortec Engine Swap Problems 5700 350 | capps | Engine | 21 | 04-06-2010 05:29 PM |
| Engine Swap - 64 Galaxie | Billy Boy | Engine | 5 | 07-21-2005 02:49 PM |
| frame swap for '57 olds wagon | chopperimpala | Suspension - Brakes - Steering | 11 | 04-10-2005 11:07 PM |
| IFS or frame swap ? | outlaw17 | Suspension - Brakes - Steering | 1 | 03-10-2003 09:00 PM |
| 57 Chevy generator to altenator swap | Rodrunner | Electrical | 2 | 07-17-2002 09:59 PM |
