Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 5700 vortec
Thread: 5700 vortec
Old 04-29-2012, 04:53 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Getting a roller cam to use with a fuel pump lobe is easy. Most of the cams that came in TPI engines have the fuel pump lobe. Or you can usually score a GM cam on Ebay on the cheap that have them as well.
Why I specified the use of a Vortec oil pan is because Vortec engines have longer bolts that are used to support the windage tray and I am unsure if the 87 and up pans have enough clearance to clear the longer bolts.
